JeffreyY's avatar
Nov 30, 2021
WiFi Router started dropping connections periodically
My router has recently started dropping device connections periodically.  To correct it, I reboot the router and connections are all fine again.  Does anyone have any suggestions or troubleshooting or solution tips?   And is there a way to tell if it is the router or my cable modem?
Thanks in advance!
I should add that I have the latest firmware version - v1.3.2.134.
Jeff
  • FURRYe38's avatar
    Any router LED colors being seen on the router when this happens?
    Do both wired and wireless devices get dropped or can't access internet services when this happens?
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    • JeffreyY's avatar
      JeffreyY
      Guide
      My ISP modem is a Spectrum Model E31U2V1
      It seems to be dropping just WiFi devices and I am not observing it dropping all wireless devices when this happens. It seems individual wireless devices lose their connection.  When this happens there is no change on the WiFi Router LED lights.
      On 2.4Ghz Channel is currently set to AUTO
      On 5 Ghz Channel is currently set to 153 (choices are 36,40,44,48, 149,153,157, 161)
      I have Enable Smart Connect - to let the router intelligently select the best WiFi band 2.4 GHz or 5 GHz for my WiFi connection
      I have neighbors around me who have WiFi through their own ISPs if that is what you are asking
      I have tried power cycling both the Modem and Router.  And this was after any firmware update, which wasn't recent.
      • FURRYe38's avatar
        On 2.4Ghz Channel is currently set to AUTO <try setting manual channel 1, 6 or 11 on 2.4Ghz
        On 5 Ghz Channel is currently set to 153 (choices are 36,40,44,48, 149,153,157, 161) and 40 to 48 channel on 5Ghz
        You can disable this and see if this helps any.
        I have neighbors around me who have WiFi through their own ISPs if that is what you are asking< How many? Possibly that having too many wifi neighbors is causing wifi noise and interferences with the router. Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
        I have tried power cycling both the Modem and Router.  And this was after any firmware update, which wasn't recent. MIght try a factory reset and setup from scratch as well.
