Buscador
May 24, 2021Aspirant
Will connecting a nighthawk router R8000 to CenturyLink C1100T modem/router improve wifi to devices
My son gave me this Nighthawk R8000 router after upgrading. I am having trouble connecting it to my CenturyLink C1100t modem/router. Before I get really involved in doing this I would like to know i...
michaelkenward
May 25, 2021Guru - Experienced User
Putting a router after a router can cause headaches.
For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point. Netgear advises this, as does just about every site you will visit.
