apgomez3
Jul 26, 2023Aspirant
Will RBS50Y work with Orbi 960?
I am looking to upgrade to the Orbi 960 for wifi 6. I currently have a RBS50Y outside. Is the RBS50Y compatible with the 960? I didn't see outdoor satellite as part of the bundle just indoor satellit...
- Jul 26, 2023
Possible it may work if you install the extender mode FW on the RBSY unit.
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
Jul 26, 2023Guru - Experienced User
