txchuko
Apr 20, 2016Guide
Will simply unplugging router to reboot cause any long term damage to it?
my Belkin router had an option to schedule reboots by selecting days and times, and I would like something similar for my nighthawk ac2350 v2, to keep things smoother since i still reset my router occasionally when a device loses/reconnects wifi over and over. a simple reboot solves the problem for a few days to a week or more.
Anyways, i am considering using a programmable electrical timer to schedule a reboot twice a week, and my question is if i simply cut the power off briefly to do reboot will it cause any damage?
I mean cutting the power off abruptly vs pressing the power button on the router or doing the reboot via the router interface
Using a timer is not an issue. Others do the same to various routers.
EDIT: Basically the power button does the same thing. Just a cleaner way of cutting power to a device.
1 Reply
- netwrksMaster
