rajpaalsinha's avatar
rajpaalsinha
Will upgrading my Nighthawk R7800 extend range?
I've been using the R7800 for years and it's been good. I was on our side yard setting up Lumary wifi controlled lights and a TV in a new outdoor bar. My phone was able to find the wifi but kept losing the signal during setup. I'm wondering if upgrading to a new Nighthawk (or possibly mesh system) would extend further outside my house.
Currently the routers signal has to travel through 3 internal and 1 external walls to reach my side yard area.
Thank you.
  • FURRYe38's avatar
    Possible. Depends on distances and building materials that can inhibit signal travel.
    Might look into a wifi extender.
  • michaelkenward's avatar
    michaelkenward
    Bit of a stretch. And the R7800 doesn't have the latest and greatest wifi technology.
    Any way of  moving the router earler to the yard area?
    If you are etending your network it might be worth lpookinh onto Netgear's Various Mesh systems.
    Try plugging your needs into the filters on the product pages:
    Wireless Routers for Home | NETGEAR
    Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
    Disclaimer: Just another user with time on their hands.
  • rajpaalsinha wrote:
    I've been using the R7800 for years and it's been good. I was on our side yard setting up Lumary wifi controlled lights and a TV in a new outdoor bar. My phone was able to find the wifi but kept losing the signal during setup. I'm wondering if upgrading to a new Nighthawk (or possibly mesh system) would extend further outside my house. https://9apps.ooo/
    Thank you.
    I got this,...
  • plemans's avatar
    How far away from the primary is it?
    Ugrading to a mesh system and putting one on the exterior wall near where the outdoor setup is might work fine. I did something similar at my home so it covers my above ground pool area. It wasn't to far away and was enough coverage to streaming
