pspec's avatar
pspec
Guide
Nov 29, 2022
win 10 pro asking for readyshare password r9000
hi all
I have the R9000 setup with 2 USB HD. I have only setup admin password and have no password set on the readyshare drives.
i have no problem accessing the HDs from 4 TVs, a handful of tablets, loads of mobile phones and 4 Laptops.
It's a different story with the new desktop which is running win 10 pro. when trying to access the dives it asks for a user name and password. readyshare is set to no password.
Oh one strange thing, if you go into This PC there's a readyshareDLNA. if i use that it shows me all media on the drives but no software without asking for password. But still no software.
any idea what going on
Thanks
  • michaelkenward's avatar
    michaelkenward
    Are these USB drives? ReadySHARE is also a part of Netgear's NAS technology. And Windows treats NAS differently.
    How are you accessing ReadySHARE from the PC?
    WifI? Wired?
    That says to me that it is a Windows issue.
    Does Windows ask for a password just for ReadySHARE? Nothing else?
    Windows can be authoritarian when it comes to security. Have you tried running the Network Wizard in Windows?
    • pspec's avatar
      pspec
      Guide
      hi
      yep 2 usb HDs
      wired
      i have a windows admin login password (tried using it but didn't work. Also tried router login password)
      It was originally setup with network wiz. but i did go in and opened up all share options..
      I say new it's a good few months old now. when i first installed win 10 pro it worked fine after i setup network share.
      Then it stopped, so went into windows and enabled SMBv1 (which i hear causes problems for Netgear routers) settings and all was good again.
      now it's stopped 😞
      i try to access the 2 drives by
      This PC icon and in then click on network/Readyshare on the left side and it asks for the password.
      The second way
      This PC then under the PC hard drives there's network location and ReadyDLNA:R9000. when i click that one I'm not asked for the password and can see video and photos read only. I can also see all folders that contain software but on opening them they appear to be empty which they aren't.
      Very Frustrating
      Thanks
        michaelkenward
        What happens when you aim Windows Explorer at:
        \\readyshare
