ivanabq
Jan 16, 2022Aspirant
Windows won't allow Private network after installing Nighthawk CAX80
I have 2 machines running Windows 11 Home. After a recent upgrade of my cable modem and router to a Nighthawk AX8/8 (CAX80), Windows will no longer retain the change in designating the network as Private rather than Public.
Any ideas?
I'm not sure how you think a windows settings not being retained is related to the router.
- ivanabqAspirant
Before installation of the CAX80 the network setting on both machines was Private. After installation, both were set as Public. Since no OS or other software change occurred, a causal relationship must be suspected.
when you change networks, windows default setting is for a public network with all new networks.
Thats it trying to protect your data. But you have to go in and change it.
If windows isn't letting you change it, thats a problem in windows.
