FairDealDave's avatar
FairDealDave
Wired Bridging an AC1900 R7000 to an RF Modem Router
I live in an area with no cable and very poor dsl.  I contracted with an ISP that uses an rf type connection to their radio tower on a local mountain top.  They provided me with an rf modem with inte...
  • antinode's avatar
    antinode
    Oct 27, 2018
    > That is exactly what I'm trying to do. [...]
       Which?  R7000 as WAP, or ISP-supplied gizmo as modem-only?
       For the R7000-as-WAP option, you may not need to know much of
    anything about the main (modem+)router.
       In AP mode, the R7000 gets a new LAN IP address, typically from the
    DHCP server in the main (modem+)router.  If the computer where you're
    trying to access the management web site of the R7000-as-WAP is
    connected to the R7000-as-WAP, then you may not notice.  If that
    computer is connected directly to the main (modem+)router, then you'd
    need to know which IP address the R7000-as-WAP got, and access it that
    way.  With any luck, the main (modem+)router will provide some kind of
    "Attached Devices" or "DHCP Clients" report where you'll be able to find
    the R7000-as-WAP, and which which will reveal the new LAN IP address of
    the R7000-as-WAP.  Otherwise, you shouldn't need to bother the main
    (modem+)router to add the R7000-as-WAP to your LAN.
       Configuring the main (modem+)router as a modem-only would demand more
    knowledge of that gizmo.
