griessen
Apr 29, 2017Aspirant
WIreless button under Basic and Advanced shows a blank page
I was able to chage the network name and password for the 2.4g, but now the Wireless button just shows a blank page on the routerlogin.net page. Which means cant change the network name for the 5g n...
- May 02, 2017
SOLVED
Apparently it's an issue with the current version of Google Chrome, which is the browser I normally use. I logged into the router with IE and was able to see and change the settings. Why it worked one time on Chrome to change the settings for the 2.4g, I have no idea. But it still shows only a blank page on both the wireless and internet settings when viewed in Chrome.
Upshot is, if something is not working in the interface, try another browser.
ElaineM
May 02, 2017NETGEAR Employee Retired
Welcome to the community, griessen
Maybe a factory reset will help.
Resetting will restore all the settings of the router to default so you will need to reconfigure it once done.
- griessenMay 02, 2017Aspirant
SOLVED
- ElaineMMay 02, 2017NETGEAR Employee Retired
Thank you for the update!
