NightFalcon
Feb 07, 2016Aspirant
Wireless network suddenly turns "off"
I have a Netgear Nighthawk R7000, which I have been using for a while now with no problems. But recently, the wifi network just dissapeared. The wifi network of the default ISP modem I have works fin...
- Feb 07, 2016
try these:
disable Arlo (Basic > Arlo)
disable then enable Wireless router Radio (Advanced > Advanced Settings > Wireless settings)
if still not working then reset is needed
storm1985
Feb 07, 2016Prodigy
If you have not reset the router yet after the latest fw update please reset the unit then manually reconfigure the settings.
If you do not need the new features of the latest fw you may downgrade to v1.0.4.30
- NightFalconFeb 07, 2016Aspirant
I highly doubt that would help, since this problem materialized before I upgraded to the latest firmware. (I was able to upgrade the firmware using the remote access link.)
- storm1985Feb 07, 2016Prodigy
try these:
