Patreek
Feb 09, 2019Tutor
Wireless Repeater Nighthawk R6700v2
According to many sources on the forums, my R6700v2 is capable of acting as a wireless repeater. I have seen a literal ton of advanced features for the router and am impressed, but I see nothing abo...
- Feb 10, 2019
I'm going to return both units and avoid Netgear all together. I honestly can't comprehend why they would include so many features I do not need on a wireless router, but not wireless repeating.
antinode
Feb 09, 2019Guru
> According to many sources on the forums, [...]
Thanks for the helpful links.
> [...] my R6700v2 is capable of acting as a wireless repeater. [...]
You couldn't prove it by the User Manual. Visit
http://netgear.com/support , put in your model number, and look for
Documentation. Get the User Manual. Look for "repeat". For a good
time, try that again for the "R7000".
> [...] This is one of the most basic uses for a wireless router [...]
Not for this one?
> [...] so I am sure I am doing something wrong.
Trusting Netgear product documentation?
> https://kb.netgear.com/24108
Trust no one, I always say. (The firmware could have changed, too.)
> [...] I have seen a literal ton of advanced features for the router
You must be using some _new_ meaning of "literal".
- PatreekFeb 09, 2019Tutor
This was posted by a forum mod here:
Yes, it seems to have support for VPN, DynamicDNS and wireless bridging but not repeating a signal... weird.
Unless you are a C programmer I don't see the point of using those ironic underscores like Linus Torvalds. It's like you're trying to let the world know you discovered PHP magic constants or Python's dunder methods.
- antinodeFeb 09, 2019Guru
> This was posted by a forum mod here: [...]
Perhaps it was true then. Firmware "updates" are not called
"upgrades" for a reason.
> Unless you are a C programmer [...]I do write some C, but I don't see its relevance. Your analysis of
simple, low-effort underlining is too deep for me. "ironic"? I was
trying for "emphatic". - michaelkenwardFeb 10, 2019Guru - Experienced User
Some Netgear routers support WDS, some don't, including the R6700v2. It is, after all, somewhere low on the performance and features scale.
I chip in only to suggest that there is a slight possibility that, while they seem to concentrate on more "upmarket" models, one of the third-party firmware writers has tweaked this device and added extra features. But this isn't the best place for that sort of discussion.
You can use the R6700v2 as a WiFi Access Point with a wired connection to a router.
- PatreekFeb 10, 2019Tutor
