goreduke
Oct 16, 2018Aspirant
Wireless router R9000 setup without modem
How can I set the router without Internet connection? I don't want an internet connection and do not have one.
- Oct 18, 2018
> [...] I tried to do it using your iPhone app but it wouldn't go beyond
> the screen where it checks for the Internet connection.
It's Netgear's "iPhone app", not mine (and Netgear may have more than
one, as the User Manual says), but I'd try the web-browser interface.
Look for "Use a Web Browser to Access the Router" in the User Manual.
[...] When you access the router, the software automatically
checks to see if your router can connect to your Internet service.
I assume that there's a way to skip that step (or wait for it to fail).
(If not, then you might need to take the thing somewhere where you can
connect it to something long enough to get it past that step.)
antinode
Oct 17, 2018Guru
What does "set the router" mean to you? Set up (configure) the
router?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Ignore the parts about
connecting to the Internet.
Is there some actual problem which you are trying to solve?
- goredukeOct 18, 2018AspirantYes, I meant "configure" ... I tried to do it using your iPhone app but it wouldn't go beyond the screen where it checks for the Internet connection.
- antinodeOct 18, 2018Guru
connect it to something long enough to get it past that step.)- goredukeOct 18, 2018Aspirant
Thank you for your patience! II'm a complete novice on this board and somehow assumed you were with Netgear and "yours" really meant "Netgear's" app.
I will try the web browser again ... I did access the router that way but was also stuck on the need for an Internet connection, but do not remember if there was anything that could serve as a workaround.
