goreduke's avatar
goreduke
Wireless router R9000 setup without modem
How can I set the router without Internet connection?  I don't want an internet connection and do not have one.
  • antinode's avatar
    antinode
    Oct 18, 2018
    > [...] I tried to do it using your iPhone app but it wouldn't go beyond
    > the screen where it checks for the Internet connection.
       It's Netgear's "iPhone app", not mine (and Netgear may have more than
    one, as the User Manual says), but I'd try the web-browser interface.
    Look for "Use a Web Browser to Access the Router" in the User Manual.
          [...] When you access the router, the software automatically
          checks to see if your router can connect to your Internet service.
    I assume that there's a way to skip that step (or wait for it to fail).
    (If not, then you might need to take the thing somewhere where you can
    connect it to something long enough to get it past that step.)
