ChrisUlrich's avatar
Nov 22, 2016
Wireless speed issue
I am trying to figure out what settings I am supposed to be using in order to utilze the downstream speeds full potential.  I have plenty of wireless ac devices, but none seem to be getting the full speed.
Here are my 5ghz settings:
Enable SSID Broadcast CHECKED
Enable Video Network UNCHECKED
CHANNEL 153 (this was default)
MODE: Up to 1733mbps
I have been using the ATT Wireless speedtest and speedtest.net.  Both net around 120mpbs down while hard wired I get 230mbps down.
Any suggestions?
  • Did exactly what you said to do!  Two other signals were on my channel (originally 153 but Netgear recommended 157).  Found a channel not being used, swapped it (channel 40), did speedtest on the iMac... pow!  232mbps down!
    Thank you so much for the advice and assistance.  Excellent directions and help.  You really made my night!
  • michaelkenward's avatar
    michaelkenward
    Wireless will never be as fast as wired.
    A lot depends on local conditions and how many devices are fighting for the bandwidth.
    Do you find that you can't do things you want? Or is this just a desire to get faster speed tests?
    Don't forget, Internet speed tests are not as reliable when you use wifi to run them. Some speedtest sites warn about this.
    • ChrisUlrich's avatar
      ChrisUlrich
      Tutor
      The idea is to make sure I am getting the speeds i'm supposed to via wireless.
      Wired is more than double my wireless connection?  I don't think that's supposed to be that way.
      • TheEther's avatar
        TheEther
        Guru
        What kind of device do you have?  If it's a PC or laptop, provide the model of the Wi-Fi adapter.
