Ikarus92
Sep 03, 2016Aspirant
WLAN config changes not possible
Hi Guys, I got a problem with my R8000. At the moment its broadcasting the default configured SSID, but for security purpose I want to configure my own SSID / PSK. But this doesn't seems to be po...
- Oct 10, 2016
Hi,
sorry, I forgot to write an answer in this topic since James forwarded the Support Contact informations to me in private.
The problem has been solved by installing the firmware "V1.0.2.44_1.0.96" on my R8000.
I'm not sure about the latest version for your EX6150, but for my R8000 the (in my opinion) stable version was listed under the previous versions section.
In your case I would suggest to install several of the older versions, and try to change the configuration to see, if the error appears again.
kind regards,
Andreas
JamesGL
Sep 04, 2016NETGEAR Employee Retired
Hi Ikarus92,
Can you post the exact error message to check what seem to be the problem.
JamesG:
Community Team
- Ikarus92Sep 05, 2016Aspirant
Hi James,
the error message "This DFS channel is not allowed to use because the Radar was detected before. You can change another channel or wait" appears after I did any configuration changes on the following menu:
In Advanced -> Setup -> Wireless Setup
But as I already reported, the second 5G-Radio isn't even active (has been deactivated under: Advanced -> Advanced Setup -> Wireless Settings) and on the first 5G-Radio there isn't a dfs-channel choosen. It's running on channel 44
kind regards
