Configuration
1 TopicWLAN config changes not possible
Hi Guys, I got a problem with my R8000. At the moment its broadcasting the default configured SSID, but for security purpose I want to configure my own SSID / PSK. But this doesn't seems to be possible. When I try to save a change on the SSID / PSK Menu, it gets cancelled: This DFS-Channel cant be used because a radar gets detected. (Error message in german, I translated it, so therefore it could be, that it isnt the exact error message on a english ui) BUT: The error appears even if the second 5G-Radio isn't even turned on, so therefore this shouldnt bother. Further, the first 5G-Radio is sending on a non-DFS-Channel, so this couldnt be the problem either. For me this seems to be a bug. I'm using V1.0.3.4_1.1.2 which seems to be the latest version. kind regards, AndreasSolved8.6KViews0likes12Comments
