Ikarus92
Sep 03, 2016Aspirant
WLAN config changes not possible
Hi Guys, I got a problem with my R8000. At the moment its broadcasting the default configured SSID, but for security purpose I want to configure my own SSID / PSK. But this doesn't seems to be po...
- Oct 10, 2016
Hi,
sorry, I forgot to write an answer in this topic since James forwarded the Support Contact informations to me in private.
The problem has been solved by installing the firmware "V1.0.2.44_1.0.96" on my R8000.
I'm not sure about the latest version for your EX6150, but for my R8000 the (in my opinion) stable version was listed under the previous versions section.
In your case I would suggest to install several of the older versions, and try to change the configuration to see, if the error appears again.
kind regards,
Andreas
Kdude
Oct 09, 2016Tutor
I have the exact same problem & get the exact error about 'DFS channel not allowed & radar was detected before'. It appears to be a bug.
I'm using the EX6150 AC1200 wifi extender & it's been installed & configured for a few months & was working without issues. Now about once a week, for no reason, the EX6150 drops the 5Ghz connection to my router (which is handling DHCP). When I try to reconnect the 5Ghz either manually or using the wizard, the EX6150 will not let me save my extisting wifi network info, and returns the error about DFS channel & radar being detected before. So I'm stuck. However, if I cycle power to the EX6150, it sometimes starts working normally again, yet other times it does not.
THIS APPEARS TO BE A NETGEAR BUG!
This post was perfectly relevant to my issue, but NetGear did not post a solution. Only told OP to check their inbox.
What is the problem? And what is the solution ?
JamesGL
Oct 09, 2016NETGEAR Employee Retired
Hi Kdude,
I would suggest posting this issue in Extender board since this is for R8000 router.
https://community.netgear.com/t5/WiFi-Range-Extenders-Repeaters/bd-p/home-wifi-range-extenders
JamesGL
Community Team
