wolframmitbach's avatar
Dec 07, 2015
WLAN schedule cannot be activated
I find this topic again and again in the forum but no solution for me.
I want to activate 'Turn off wireless signal by schedule' but the box cannot be checked.
I'm using the R7000 as a Router it's on the latest FW V1.0.5.48_1.1.79 using a Chrome browser w Windows 10. (Edge doesn't work either)
Please Help
PS: There's no way to send a simple question to netgear support - thanks netgear! :-(((((
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi wolframmibach,
    Please reset the router to factory default and check if the you can enable it. By the way, was it working before prior to upgrading the firmware?
      • JamesGL's avatar
        JamesGL
        Glad to know it works now.
