Pop9's avatar
Pop9
Guide
May 27, 2022
WLAN0 Tuya Connected Randomly to My Networks
As stated, this device read only connected to my network. I searched the MAC address of 18:69:D8:4F:78:2B and it says manufactured by Tuya. I have no clue what this device is though. Any insight would be appreciated.
  • FURRYe38's avatar
    Do a web search on the mac addresss and that brand name.
    What NG product are you using?
      • FURRYe38's avatar
        OH there it is. Thank you.
        What happens if you change the wifi SSID name and PW to something else temporarily. Does that MAC address and device still appear?
        Change back after checking this.
        Do a web search on the brand name you find.
  • plemans's avatar
    got some smart devices? Tuya is platform for smart devices. I've got a couple on my network. I think lightbulbs or switches that use it.
    https://www.tuya.com/
    • Pop9's avatar
      Pop9
      Guide
      I do. But this one randomly connected at 4 in the morning which is throwing me off because I didn’t do anything at that time.
      • plemans's avatar
        Maybe one of the IoT devices updated its firmware in the background?
