jpr35
Mar 02, 2021Aspirant
WNR2000-5 in AP mode doesn't prevent guest user to access my personal home network
Hello there
I have been using a WNR2000v5 in AP mode for a few years, and recently i discovered that my guest can acces my home network by using the WiFi guest network .
I beleived that using the WNR2000v5 in this mode the 2 networks were distincts, see data sheet :
Guest networks create a
completely separate WiFi network for your guests’
devices so they do not have access to your home
I am wondering if i have skiped something when i installed this device
I have attached some screenshots showing the settings, and for example there is something i can't explain between Screen 1 and Screen 2, they are contradictory
Screen 1 : In french, but means : Allow guest to see each other and access my local network, this check box is OFF
Screen 2 : Same setting but different display, it is ON
in addition when you setup the router in AP mode for thze first time, you can't modify these settings, it is the default configuration , i mean OFF
-Screen 3 shows the entire network, the WNR2000v5 is harwired to the Ethernet port 4 of the Orange router (Livebox 5) and the guest WiFi network is behind
-Screen 4 shows that i can access my NAS on my home network
Others :
-The network is managed by an ISP router (Livebox 5 from Orange ) Fiber modem .
-my laptop is a MACBOOK PRO
Hope my description is clear enough, don't hesitate to ask for furthermore inputs.
I look forward to getting some advices
Thanks in advance
OK thanks
> [...] WNR2000v5 in AP mode [...]
How, exactly, did you do that? "Use the Router as a Wireless Access
Point" in the WNR2000v5 User Manual, or some other scheme?The following router features are not available (grayed out) when
the router is in AP mode:Guest Network
[...]"Guest Network" is a router feature, not a wireless-access-point
feature.> Guest networks create a completely separate WiFi network [...]
Not the most accurate description, I'd say.
On these routers, a "guest network" is not a separate network, but
there are firewall-like rules (enabled by default) which can limit the
ability of "guest" client devices to communicate with non-guest client
devices. (Those firewall-like rules are implemented in the router
section of the device, which is why that functionality is lost when the
router is configured as a wireless access point.)I can't (yet) see your pictures. In-line images must be approved
by a moderator before others can see them. The time required varies.
Attachments have no such limitation. Of course, attachments have their
own one-per-message limitation.--------
Your pictures seem to have been rejected.- jpr35Aspirant
Hello Antinode
Thanks for your reactivity and your explanations
1) As far as i undertsand your answer, the network isolation between WiFi guest network and my domestic network is not possible , because this feature doesn't exist in AP mode .
2) I had not understood this point before buying this router, despites the questions i asked to the Netgear advisor in France, anyway ...
3) Let me explain what i try to make :
-I am renting an appartment in my property which is too far from my home to receive the WiFi signal from my ISP modem router, and in order to overcome this problem, i have installed in the guest appartment the WNR2000v5 (the device is hidden behind a piece of furniture) which is linked to my router with a CAT6 Ethernet cable.The aim is to offer Internet acces only to the guest and prevent him to acces my home network.
4) is there a way to acheive point 3 objective ? for example by using the WNR2000v5 in router mode behind my ISP router , knowing i cannot use the WNR2000v5 in the place of the ISP router .
Thanks a lot in advance
Kind regards
> [...] for example by using the WNR2000v5 in router mode behind my ISP
> router [...]You can try that. Cascading multiple routers can cause problems for
servers and some games (double NAT, for example), but for simple web
browsing and the like, it might do well enough.- jpr35Aspirant
OK thanks
