StanleyY's avatar
StanleyY
Follower
Oct 20, 2021
Would Nighthawk M5 5G WiFi 6 Mobile Router Unlocked works in Hong Kong?
Hello community,
I would like to know if Nighthawk M5 5G WiFi 6 Mobile Router unlocked works in Hong Kong Region?
I checked Hong Kong 5G frequency band are n1, n78 and n79, so I assume that is working fine in Hong Kong.
However this unlocked version is suitable for HK telecom? That's what I am asking.
Thank you so much!!
1 Reply
  • michaelkenward's avatar
    michaelkenward
    A question for the section dedicated to those devices.
    Mobile Routers, Hotspots & Modems
    Those things are very different from the standard Netgear routers covered in this section.
