alokeprasad
May 26, 2017Mentor
WPS setting "Keep Existing Wireless Settings"
What is this? I find the documentation inadequate. "Keep Existing Wireless Settings This shows whether the router is in the WPS configured state. If this option is not selected, adding a new w...
- May 29, 2017
Hi alokeprasad,,
If you will not use WPS, the "Keep Existing Wireless Settings" is no use. You may disable it if you want. But to be safe just in case someone uses the WPS, which will change the wireless settings everytime someone uses the WPS if disabled, keep it enabled.
JamesGL
May 29, 2017NETGEAR Employee Retired
Hi alokeprasad,,
- JamesGLJun 04, 2017NETGEAR Employee Retired
Hi alokeprasad,,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
