alokeprasad's avatar
Dec 01, 2016
X10 - configure over wifi - how secure is it?
I have always disabled the "configure over wifi" feature of my routers (from Netgear or others) in the past.  I figured that this was more secure, as someone will need physical access to my wired LAN...
  • TheEther's avatar
    Dec 01, 2016
    alokeprasad wrote:
    I have always disabled the "configure over wifi" feature of my routers (from Netgear or others) in the past.  I figured that this was more secure, as someone will need physical access to my wired LAN to change settings of my router.  However, I lose the ability to effectively use the iPhone apps, even when at home, to admin the device....
    Should I continue that habit?  Am I being unneccesarily paranoid?
    [Edit: I realize that if I use WPA2 encryption, someone will need to know my password to access my network over wifi.  However, my neighbor (or a van parked on the street) can brute-force password attacks over wifi.  Not broadcasting SSID is not an effective way for against packet sniffers]
    It's always good to be cautious and vigilant but it is relatively safe to use wireless.  I did, however, warn someone recently that it was a really bad idea to run with no encryption between two repeaters because he was sure his Wi-Fi signal was too weak to be picked up outside his house.  :smileysad:
    It is computationally impossible to brute-force a strong WPA2-PSK password.  "Strong" would be a random password of 16 characters or longer.
    Note: I will ALWAYS disable remote access (over internet/WAN) to the router.
    Specific questions about the X10 (mine is on order):
    1. Can I disable access to the router configuration over wireless?
    No.
    2. Should I do that?
    N/A
    3. OT question: What is the default IP address of the router in the 192.168.x.x range? In case the http://www.routerlogin.net cannot be resolved..
    192.168.1.1.  Have a look at the online manual while you wait for it to arrive.
    4. Can I disable WPS connections?  Should I?
    You cannot fully disable WPS, but you can disable the PIN-based method, which I recommend doing.  That still leaves the push-button method, but if you can physically secure access to your router, you will be ok.
