Izlude
Jun 26, 2025Aspirant
X10 question, 2.5Gbit solutions etc..
Hi all, I bought a Nighthawk X10 a while back for $10 at thrift. Love this thing, but I'm now faced with a forced upgrade from my ISP (no complaints, it's the same price). My issue: the X10's port...
- Jun 27, 2025
So ya, you can configure the SPF port for WAN side configuration:
My router has Voxel FW loaded since NG stock went EoL. So you could load his FW up and get a bit more support and operation from the R9000.
Let us know how it goes.
Izlude
Major oversight on my part. I just realized the WAN port on the x10 is limited to 1Gbit input :'( that means I'll lose the extra 200mbit from the ISP if I continue using this router. Darn... should I opt for an RS100 then?
- FURRYe38Jun 26, 2025Guru - Experienced User
Something that has a 2.5Gb or higher WAN port support.
Even a RAX120/200 or RAXE500 has options as well however are older models.
