Izlude
Jun 26, 2025Aspirant
X10 question, 2.5Gbit solutions etc..
Hi all, I bought a Nighthawk X10 a while back for $10 at thrift. Love this thing, but I'm now faced with a forced upgrade from my ISP (no complaints, it's the same price). My issue: the X10's port...
- Jun 27, 2025
So ya, you can configure the SPF port for WAN side configuration:
My router has Voxel FW loaded since NG stock went EoL. So you could load his FW up and get a bit more support and operation from the R9000.
Let us know how it goes.
Jun 26, 2025Guru - Experienced User
Where is the configuration done on the R9000 for the SFP port? I don't remember where thats at...
Kitsap
Jun 27, 2025Master
My X10 is no longer in service. I recall it being in the WAN setup section.
- FURRYe38Jun 27, 2025Guru - Experienced User
K, I'll see if I can dust mine off and take a quick look and see if this there. Been a while.
