computim's avatar
computim
Luminary
Oct 02, 2018
X10 R9000 Firmware 1.0.4.12 DO NOT UPGRADE(WILL BREAK 5GHZ)
Updated my firmware from 1.0.4.2 to the latest 1.0.4.12 as usual did the factory reset and restored backup config.  Immediately my 5Ghz connected devices began pausing and having momentary disconnect...
  • schumaku's avatar
    schumaku
    Nov 10, 2018
    computim wrote:
    1.0.4.18?  R8000 has that firmware but I've not seen nor heard of it for the R9000.
    Do as advised by Altsai - customer support is able to provide you with 1.0.4.18.
    Alternate, request access to the R9000 early adopters community with ChristineT or Christian_R
