computim
Oct 02, 2018Luminary
X10 R9000 Firmware 1.0.4.12 DO NOT UPGRADE(WILL BREAK 5GHZ)
Updated my firmware from 1.0.4.2 to the latest 1.0.4.12 as usual did the factory reset and restored backup config. Immediately my 5Ghz connected devices began pausing and having momentary disconnect...
- Nov 10, 2018
computim wrote:
1.0.4.18? R8000 has that firmware but I've not seen nor heard of it for the R9000.
Do as advised by Altsai - customer support is able to provide you with 1.0.4.18.
Alternate, request access to the R9000 early adopters community with ChristineT or Christian_R
Wout
Oct 23, 2018Tutor
Hier had ik het netjes ingesteld op kanaal 11 maar met de laatste software springt hij terug naar kanaal 1, zet ik hem op kanaal13 dan springt hij nog terug naar kanaal 1.
Op de Nederlandse site zeggen ze gewoon "even afwachten", dat is de gebruikers niet serieus nemen maar zo komt netgear nu wel over.
Dit gewoon in het Nederlands omdat er wel Netgear site is maar de community is weer Engels.
WB
schumaku
Oct 23, 2018Guru - Experienced User
Hi WB,
.12 did run 2.4 GHz on the configured Channel 3 (3+7 to be exact), and so does a slightly newer firmware version I'm driving for tests.
For the other part, well, processes and changes seem to very slow - still awaiting the promised R9000 new "test" program.
-Kurt
