computim
Oct 02, 2018Luminary
X10 R9000 Firmware 1.0.4.12 DO NOT UPGRADE(WILL BREAK 5GHZ)
Updated my firmware from 1.0.4.2 to the latest 1.0.4.12 as usual did the factory reset and restored backup config. Immediately my 5Ghz connected devices began pausing and having momentary disconnect...
- Nov 10, 2018
computim wrote:
1.0.4.18? R8000 has that firmware but I've not seen nor heard of it for the R9000.
Do as advised by Altsai - customer support is able to provide you with 1.0.4.18.
Alternate, request access to the R9000 early adopters community with ChristineT or Christian_R
Altsai
Nov 07, 2018NETGEAR Expert
which FW version did you use?
I heard v1.0.4.18 is more stable, so I suggest you to contact NTGR support team to download this version.
computim
Nov 10, 2018Luminary
- schumakuNov 10, 2018Guru - Experienced User
- computimNov 11, 2018Luminary
Thank you for the contact. I've been granted access to the beta page. I will swap back to my second r9000 and apply for testing. Any issues experienced with the 5ghz dropping momentarily and then reconnecting?
