computim
Oct 02, 2018Luminary
X10 R9000 Firmware 1.0.4.12 DO NOT UPGRADE(WILL BREAK 5GHZ)
Updated my firmware from 1.0.4.2 to the latest 1.0.4.12 as usual did the factory reset and restored backup config. Immediately my 5Ghz connected devices began pausing and having momentary disconnect...
- Nov 10, 2018
computim wrote:
1.0.4.18? R8000 has that firmware but I've not seen nor heard of it for the R9000.
Do as advised by Altsai - customer support is able to provide you with 1.0.4.18.
Alternate, request access to the R9000 early adopters community with ChristineT or Christian_R
Wout
Jan 16, 2019Tutor
Nieuwe firmware 1.0.4.26 is nog erger, een niet geteste ramp en te schandalig voor woorden.
Altsai
Jan 17, 2019NETGEAR Expert
I have upgraded to v1.0.4.26 and not encounter the same issue you posted. Did you ever try "reset-to-factory" default?
- WoutJan 17, 2019Tutor
Hier ben ik teruggegaan naar de versie 1.0.4.12 en daarin kon ik de WiFi weer aanzetten, daarna de router, met de versie en taal op Engels gereset en de nieuwe firmware er weer in gezet.
Nu werkt het zoals de bedoeling zou zijn. ;)
- computimJan 17, 2019LuminaryI've updated along the way and .26 is the most stable at this point. Although it's still not perfect as others have replied with issues that still exist. However, the wifi on 26 is working much better that the version I stated to not install.
