mrmagloo
Apr 13, 2017Apprentice
X4 R7500v2 New Firmware Rolls back QoS???
In the last couple of weeks I hit the firmware update button to check for anything new, and it installed 1.0.3.10. I thought cool. Then I went over to QoS and checked for an update there. It was ru...
- Apr 25, 2017
I just checked and it will update to June 2016. Thank you! Noting that this update is nearly a year old, can you say if this will update again, and what is the normal frequency? Thanks Elaine.
mrmagloo
Apr 14, 2017Apprentice
Here is the version it rolled back to:
| Version: v2.0421.cloud-ga |
| Release Date: April 21, 2015 |
It will not allow me to go forward to the previous version I had from June 2016. Even then, that was 10 Months old. Does this QoS database ever get updated on a regular basis?
Please advise.
mrmagloo
Apr 17, 2017Apprentice
Hello?? 108 Views so far, and not a single moderator/tech in sight?
- mrmaglooApr 19, 2017Apprentice
Hmm, still nothing?
- FURRYe38Apr 19, 2017Guru - Experienced User
Could that they rolled back the QoS services to 2015 due to something they found or maybe it resets back to 2015 and needs some time to maybe on date on your router. I'd give it a day and check back to see if it's been updated or not. Might contact one of the forum moderators or phone contact NG support if it doesn't update.
Hi FN - I've been checking it every day for the past week. Enabling QoS, checking for updates, and none available. So I turn it back off again.
From what I read in previous posts regarding Firmware updates affecting QoS, it's pretty clear that in each version there has to be an up to date security key. This issue was reviewed and sorted out with a past version.
While I believe that all these QoS updates do is provide better or more updated recognition for connected devices, the point is, this is pretty basic stuff. 'Advanced Qos' is supposed to be a big feature, and it's kind of amazing that a high tech company can blow it so badly, so often. Then ignore the issue. V1.0.6.10 seems to have been released within the last month, so you'd think they'd be monitoring the rollout. Nope.
