mrmagloo
Apr 14, 2017Apprentice
X4 R7500v2 New Firmware Rolls back QoS???
In the last couple of weeks I hit the firmware update button to check for anything new, and it installed 1.0.3.10. I thought cool. Then I went over to QoS and checked for an update there. It was ru...
- Apr 25, 2017
I just checked and it will update to June 2016. Thank you! Noting that this update is nearly a year old, can you say if this will update again, and what is the normal frequency? Thanks Elaine.
Apr 19, 2017Guru - Experienced User
I'd send Elaine a PM to get more of a quicker responce. Good Luck.
ElaineM
Apr 25, 2017NETGEAR Employee Retired
I received a confirmation that this has been fixed.
Can you guys update the database and verify?
- mrmaglooApr 25, 2017Apprentice
- ElaineMApr 25, 2017NETGEAR Employee Retired
Our engineers are working to update these QoS databases on all our routers.
Just recently, we updated the one for R9000 and most likely the rest of the Nighthawk router portfolio will get an update.I do not have an ETA but they are aware since this has been brought up in several threads already.
Thanks for the update Elaine!
You're very welcome!
