RobbieBeats's avatar
RobbieBeats
X4S R7800 Higher Ping
Hi,
I recently purchased the X4S R7800 Router. I went through all of the set up this morning. I put my ISP gateway into passthrough mode and disabled the wifi. I've connected my PS5 to the Nighthawk via Ethernet, but when I load up a game of FIFA, I'm getting 60-70% higher ping than previously when I was connected to the gateway via ethernet cable. I'm seeing 46-48ms ping compared to 26-28ms previously. It's not an enormous change obviously, but I did want to reduce that as much as possible, as I don't think there should have been any difference.
Let me know if there's anything different I should try and thanks in advance for the help.
  • michaelkenward's avatar
    michaelkenward
    It might help if you told people what that gateway is.
    Passthrough mode is one of those terms that can mean various things. A genuine "bridge mode" that disables the router bit of a gateway would also disable wifi – no need to tirn it off – because that needs a router to work Just turning it off does not mean that the router bit is disabled.
