jmpedron's avatar
jmpedron
Follower
Aug 30, 2017
X6S Extender – Will it connect to Orbi's dedicated 5G backhaul?
  • Hi jmpedron,
    Thanks for your question. Nighthawk X6S is intended to work with any router or gateway and provide extreme speed and coverage by using one of the tri-band radios to connect with the router. It can work with Orbi but cannot connect to the dedicated backhaul of Orbi since Orbi is a closed system.
1 Reply
  • arunkmony's avatar
    arunkmony
    NETGEAR Employee Retired
    Hi jmpedron,
