MON5TERMATT
Aug 30, 2017Follower
X6S Extender - Will it support multiple networks?
Hi MONSTERMATT,
Thanks for your question. I am not sure I understood multiple networks clearly. If you mean to say more than one X6S talking to your router, yes, that's possible. If you are talking about different SSID combinations, yes there is flexibility to configure X6S extender with same ssid or different ssid as your router.
1 Reply
- arunkmonyNETGEAR Employee Retired
Hi MONSTERMATT,
