chxu
Feb 05, 2022Follower
Yamaha MusicCast does not appear in wifi
My routher is Nighthawk X6S AC3000 Tri-Band WiFi Router Model R7900P. I connect my yamaha r-n303bl network Receiver with Cable to Router directly. Airplay can find the Receiver and works very well. I am trying to set up Yamaha MusicCast Control App via my iPhone. However, the MusicCast can not appear in the Wifi setting and the App setup can not go through. I followed the instruction step by step and did not make any mistake. I guess there is a compatible issue bewteen Nightthaw Router and MusicCast?
Great thanks for your answer and suggestion.
You'd have to check with yamaha on specifics with their device. They'll be the expert on setting it up.
