dado80's avatar
dado80
Tutor
Jan 14, 2017
NETGEAR D7000: Android VPN issue
Hi all I'm trying to use VPN from my Android device (Samsung S7 edge) to connect to my home router. I set up DDNS, downloaded files on my phone and created the OpenVPN profile. I can connect th...
  • ElisabettaL's avatar
    ElisabettaL
    Jan 24, 2017
    Gentilssimo,
    il problema dovrebbe essere risolto con la prossima release del firmware.
    Saluti
    Elisabetta
    Team NETGEAR
