doriano's avatar
doriano
NETGEAR ROUTER MODELLO D6000
Buon giorno
ho un problema con l'aggiornamento del mio router _D6000 acquistati nel febbraio 2016
con Netgear Genie il firmware indica il router aggiornato alla versione V1.0.0.61 ma ho visto che nella sessione download siamo alla 1.0.0.68
ho scaricato il file per tentare aggiornamento in manuale ma quando mi collego a http://www.routerlogin.net  mi richiede account e password per proseguire
cosa si può fare? E' normale che l'App Genie non aggiorni ai nuovi firmware il router?
grazie a tutti
Doriano
  • > ho scaricato il file per tentare aggiornamento in manuale ma quando mi
    > proseguire
    GT> I downloaded the file to try updating in manual but when I connect
    GT> to http://www.routerlogin.net requires me account and password to
    GT> continue
       The default user and password are "admin" and "password".
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual.  Read.
    > [...] E' normale che l'App Genie non aggiorni ai nuovi firmware il
    > router?
    GT> Is it normal for the Genie App not to update the router to the new
    GT> firmware?
       I don't know.  I don't use the Genie app.  I use a web browser
    (pointed at routerlogin.net).  (But I know my "admin" password.)
    • doriano's avatar
      doriano
      Hello
      the firmware update has been resolved by after that, if i use the app Netgear Genie on my desktop pc when i select the router setting box i rcvd the following answer: login failed the router response timed out
      before the firmware upgrade the pc app properly well work
      tks
      Doriano
      • michaelkenward's avatar
        michaelkenward
        Did you reset the router to factory settings after the firmware flash?
        New firmware sometimes introduces changes that are not compatible with the old configuration.
        So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
