Luca28
Jul 10, 2022Aspirant
nordvpn hybrid vpn non funziona
buongiorno ho seguito le istruzioni per configurare nordvpn su hybrid vpn ma quando vado ad inserire lo script con annesse credenziali nelle impostazioni avanazate della hybrid vpn non si collega. v...
Jul 10, 2022Guru - Experienced User
In inglese per favore
- Luca28Jul 11, 2022Aspirant
hello Netduma-Fraser, I followed the instructions to configure nordvpn on hybrid vpn but when I go to insert the script with attached credentials in the advanced settings of the hybrid vpn it does not connect.
I leave you the register:
Sun Jul 10 17:29:08 2022 OpenVPN 2.4.3 arm-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH / PKTINFO] [AEAD] built on Jan 24 2022 Sun Jul 10 17:29:08 2022 library versions: OpenSSL 1.0.2n 7 Dec 2017, LZO 2.06 Sun Jul 10 17:29:08 2022 WARNING: --ping should normally be used with --ping-restart or --ping-exit Sun Jul 10 17:29:08 2022 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts Sun Jul 10 17:29:08 2022 Non-Hex character ('G') found at line 20 in key file '[[INLINE]]' (240/128/256 bytes found / min / max) Sun Jul 10 17:29:08 2022 Exiting due to fatal error
i talked to the nordvpn team and it seems to be my xr500 can't read all the information.
below I also leave the script (removing the key)
client dev tun proto udp remote 185.153.176.218 1194 resolv-retry infinite remote-random nobind tun-mtu 1500 tun-mtu-extra 32 mssfix 1450 persist-key persist-tun ping 15 ping-restart 0 ping-timer-rem reneg-sec 0 comp-lzo no remote-cert-tls server auth-user-pass verb 3 pull fast-io cipher AES-256-CBC auth SHA512 <ca>
