Luca28
Jul 10, 2022Aspirant
nordvpn hybrid vpn non funziona
buongiorno ho seguito le istruzioni per configurare nordvpn su hybrid vpn ma quando vado ad inserire lo script con annesse credenziali nelle impostazioni avanazate della hybrid vpn non si collega. v...
Netduma-Fraser
Jul 10, 2022NetDuma Partner
Can you try removing the spaces above and below remote-cert please and try again?
Luca28
Jul 11, 2022Aspirant
I tried to do as you asked me but always the same error.
I report it below
Mon Jul 11 14:59:27 2022 OpenVPN 2.4.3 arm-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Jan 24 2022 Mon Jul 11 14:59:27 2022 library versions: OpenSSL 1.0.2n 7 Dec 2017, LZO 2.06 Mon Jul 11 14:59:27 2022 WARNING: --ping should normally be used with --ping-restart or --ping-exit Mon Jul 11 14:59:27 2022 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts Mon Jul 11 14:59:27 2022 Non-Hex character ('G') found at line 20 in key file '[[INLINE]]' (240/128/256 bytes found/min/max) Mon Jul 11 14:59:27 2022 Exiting due to fatal error
