AleFonPal's avatar
Jun 19, 2017
RSync fail version 6.7.4
After installing version 6.7.4 on ReadyNas 312, backup file from Ready nas to another storage using Rsync doesn't work anymore. This is log.
Can anyone help me?
Backup Job Name: Pal02_rep
Backup Job Type: Incremental
Protocol: rsync
Backup Source: [volume:data]/
Backup Destination: [remote:rsync]/192.168.15.5::AleTest
Backup Start Time: Mon Jun 19 2017 19:25:53
Backup Finish Time: Mon Jun 19 2017 19:25:54
Backup Status: Success
sending incremental file list
sent 772 bytes received 121 bytes 1,786.00 bytes/sec
total size is 0 speedup is 0.00
L_TYPE_ACCESS): Operation not supported (95)
rsync: set_acl: sys_acl_set_file(data/ArtinfoMigrazione, ACL_TYPE_DEFAULT): Operation not supported (95)
data/BckConfig/
rsync: set_acl: sys_acl_set_file(data/BckConfig, ACL_TYPE_ACCESS): Operation not supported (95)
rsync: set_acl: sys_acl_set_file(data/BckConfig, ACL_TYPE_DEFAULT): Operation not supported (95)
data/CarLav/
rsync: set_acl: sys_acl_set_file(data/CarLav, ACL_TYPE_ACCESS): Operation not supported (95)
rsync: set_acl: sys_acl_set_file(data/CarLav, ACL_TYPE_DEFAULT): Operation not supported (95)
data/Caronte/
rsync: set_acl: sys_acl_set_file(data/Caronte, ACL_TYPE_ACCESS): Operation not supported (95)
rsync: set_acl: sys_acl_set_file(data/Caronte, ACL_TYPE_DEFAULT): Operation not supported (95)
data/Commerciale/
sent 868 bytes received 4,267 bytes 3,423.33 bytes/sec
rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1183) [sender=3.1.1]
  • Dopo l'aggiornamento è tornato a funzionare tutto correttamente.
    Molte grazie.
  • Ciao a tutti,
    Dopo l'installazione della versione 6.7.4 su un ReadyNas 312, il backup dal ReadyNas verso un'altro server utilizzando Rsync non funziona più!
    Segue il log con gli errori.
    Protocol: rsync
    data/BckConfig/
    data/CarLav/
    data/Caronte/
    data/Commerciale/
    • EvelinaS's avatar
      EvelinaS
      NETGEAR Employee Retired
      Gentile AleFonPal,
      Grazie per aver scritto in Italiano. Provi a creare una cartella nuova e un nuovo backup. Il problema persiste?
      Saluti,
      Evelina
      Team NETGEAR
      • EvelinaS's avatar
        EvelinaS
        Grazie per la risposta.
        Ora è disponibile la nuova versione del firmware 6.7.5:
        https://kb.netgear.com/000038857/ReadyNAS-OS-6-Software-Version-6-7-5
        Aggiorni il suo ReadyNAS e verifichi il funzionamento del Backup. Se la problematica si ripresenta, la prego di inviarmi tramite un messaggio privato gli screen shot con le impostazioni relative al backup.
        Rimaniamo in attesa di sue notizie.
        Saluti,
        Evelina
        Team NETGEAR
  • EvelinaS's avatar
    EvelinaS
    Salve AleFonPal,
    Grazie per il post e Benvenuto nella Community!
    Potrebbe gentilmente scrivere la sua domanda in Italiano in modo che altri utenti possono leggerla? Se preferisce scrivere in inglese la invito a postare la sua domanda sulla Community in lingua Inglese
    Cordiali Saluti,
    Evelina
    Team NETGEAR
