Lino1974
Oct 18, 2025Aspirant
problemi accesso ready nas duo
Ciao a tutti sto cambiando l' hdd al mio Ready nas duo ma ho un problema quando vado nella pagina amministrazione da Raidar mi esce questo messaggio e non posso fare nulla Il sito non può fornire...
- Oct 18, 2025
Lino1974 wrote:
192.168.1.46 uses an unsupported protocol.
ERR_SSL_VERSION_OR_CIPHER_MISMATCHThis has been an issue for a couple of years, so you must not have logged in recently. Your NAS doesn't support TLS 1.2, and most new browsers require that protocol.
You can work around the problem using Firefox. Set security.tls.version.min to 1 (browse to about:config and search for the setting).
Once you have access, there are a couple of other options, but they depend on exactly what model you have. Are you running:
- 4.1.x firmware?
- 5.3.x firmware? or
- 4.2.x firmware?
Lino1974 wrote:
I can't do anything, not even format the disk.
What RAID mode are you using? Normally you don't need to format the disk from the UI, that is done automatically.
Also, what disk model do you want to install? Some use shingled magnetic recording (SMR), which are not good choices for RAID.
Oct 18, 2025Guru - Experienced User
Lino1974 wrote:192.168.1.46 uses an unsupported protocol.
- 4.1.x firmware?
- 4.2.x firmware?
Lino1974 wrote:I can't do anything, not even format the disk.
Lino1974
Oct 20, 2025Aspirant
But I wanted to do this step. Can it be done in Chrome too? If so, how? Thanks.
Migliora le tue competenze con la Netgear Academy - Formati, certificati e rimani aggiornato con la tecnologia Netgear più recente!
Unisciti a noi!
ProSupport for Business
Piani di supporto completi per l'ottimizzazione della tua rete e la tranquillità della tua azienda.
