SinQ's avatar
SinQ
RBR850をアップデートしたらRBS350が繋がらなくなった
こんにちは
自宅のRBR850をv7.2.6.31へアップデートしました。
RBS850は問題なく接続されますが、
RBS350が接続されなくなりました。リセットや再登録を試すも追加できず失敗してしまいます。
RBR850のファームウェアをv4最後のv4.6.9.11へ戻したところ接続できました。
何度か行いましたが、ルーターがv7台になるとv4までしかないRBS350を見失うようです。
なにか解決方法はありますでしょうか?
よろしくお願いいたします。
I am writing to report an issue I encountered after updating the firmware on my Netgear Orbi RBR850 to version v7.2.6.31.
While my RBS850 satellite connects without any problems, my RBS350 satellite is no longer able to connect to the network.
I have attempted to reset and re-register the RBS350 multiple times, but have been unsuccessful in adding it back to the system.
Interestingly, when I downgraded the firmware on my RBR850 back to the last v4 version, v4.6.9.11, the RBS350 was able to connect successfully.
I have repeated this process several times and it appears that the RBR850, when running firmware in the v7 range, is unable to recognize the RBS350, which only supports firmware up to v4.
Could you please advise if there is a known solution or workaround for this compatibility issue between the latest RBR850 firmware and the RBS350 satellite?
Thank you for your time and assistance.
Sincerely,
No RepliesBe the first to reply
