Sjw1au's avatar
Sjw1au
Follower
Jul 19, 2025
Ability to read traffic
Hi All I am attempting to find any log on the router that show me all the traffic in and out of the router.
I can see the very basic logs are but it doesn't provide enough information.
Can some please assist.
Thanks
1 Reply
  • CrimpOn's avatar
    CrimpOn
    Many Netgear routers have a "debug" option which will capture every packet on the WAN interface.
    Please check this conversation...
    Nighthawk RS700 tip | NETGEAR Communities
    i.e. open <IP of router>/debut.htm
    I found that my Orbi router did not capture enough data to be useful, so my solution (Geek Alert) was to:
    • Place a 'managed' Ethernet switch between the router and ISP modem.
    • Connect the router WAN interface to Port 1 of the switch.
    • Connect the ISP modem to Port 2 ot the switch.
    • Mirror port 1 of the switch to Port 3 of the switch (for both "in" and "out")
    • Connect Port 3 of the switch to an Ethernet port on my PC
    • Open Wireshark on the PC to record everything that appeared on that Ethernet adapter.
    One time, I wanted to document the DHCP behavior of my ISP over an entire week.  Realizing that this long of a data capture would be many gigabytes, I defined a Wireshark capture filter to record only DHCP (both v4 and v6).  After a week, it became clear that my ISP issued DHCP leases of one day for IPv4 and one week for IPv6.
    Good Luck
