Spicyalan's avatar
Spicyalan
Follower
Feb 01, 2024
Abnormal IP and connection failure after disabling smart connect - RS700
RS700 - Firmware Version V1.0.7.82_2.0.80
After disabling the smart connect (which means separate the 2.4Ghz, 5Ghz, and 6Ghz), all the mobile devices can't connect to the router, and the devices get weird IP.
1 Reply
  • BH_C's avatar
    BH_C
    NETGEAR Expert
    We have a trial firmware that may fix this issue? would you like to give it a try?
    I will PM you the firmware link. Thanks.
