piyopiyo320
Oct 19, 2025Tutor
Access Control - Nighthawk RS600 "Whack-a-mole"
Router Firmware Version V1.0.5.12 I am using a Nighthawk RS600 along with a BE5000 (version EXS27 firmware v1.0.1.34) WiFi Extender. The issue that I am running into is that when I turn on Access...
Oct 19, 2025Guru - Experienced User
Does this happen with out the extender being online?
Might try updating the RS router as well. There is newer FW available: https://www.netgear.com/support/product/rs600
piyopiyo320
Oct 19, 2025Tutor
We manually updated the firmware to the latest. Unfortunately, even with the extender unplugged, the Xbox was still showing as 'Blocked' even after changing setting to 'Allowed'
- FURRYe38Oct 20, 2025Guru - Experienced User
I recommend factory reset the router then setup from scratch.
Set up some IP address reservations for devices that your trying to use with Access Controls.
