Squeeks99's avatar
Squeeks99
BE18000 RS600 Tri-band SSID Issue
I just bought the BE18000 RS600 Tri-band WiFi 7 router and no matter what I try during configuration (either Web or Nighthawk app) I cannot disable the SSID.
Using the Web interface I uncheck the SSID broadcast option - but two of the network SSIDs are still being broadcast. I have rebooted the router also, to no avail.
How do you turn off the SSID broadcast?
Any help would be greatly appreciated.
Many thanks!
  • All check boxes  for each radio have to be unchecked for each radio for all fo them to be disabled. How I have mine currently. 😉
1 Reply
  • FURRYe38's avatar
