alray1989
Oct 21, 2025Aspirant
BE9300 - Cannot connect any device
MY Samsung Q60 TV, Fire tablet, Ring doorbell, Amazon Echo. None will connect. Previous NIghthawk router I had no problem. Have rebooted everything. Tried to enter IP manually. Still wiil not c...
Oct 22, 2025Guru - Experienced User
Use same SSID name and password and prior router?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
alray1989 wrote:MY Samsung Q60 TV, Fire tablet, Ring doorbell, Amazon Echo. None will connect.
Still wiil not connect.
Thanks for any advice.
