ZeddsDeadBaby
Jan 25, 2026Tutor
Blocked Texts
Hello, I recently noticed some of my texts are being blocked on my iphone but only when I am connected to the RS700 router. I also use Netgear Armor on the router and downloaded app on the phone...
Jan 26, 2026Guru - Experienced User
What happens if you disable Armor?
I'm getting texts on my iphone 17 from my RS700. Trial Armor is enabled.
What phone platform do you have? Apple or Android?
Using ISP detected DNS or Custom DNS?
Is IPv6 enabled on the router?
ZeddsDeadBaby
Jan 26, 2026Tutor
I forgot to mention its only happening to my phone on the network. Not my wife's. And it’s only just started happening to my phone in the last month maybe.
iPhone Apple 16 PMax. latest update for phone, router, and apps.
Armor on the phone is only monitoring scams setting. It is turned on through the NG router settings, but again its
ISP auto detected. No PV6 enabled.
I am trying different phone settings. Like turning off rcs. And private wifi address. Idk. No clue why its an issue now.
i have read that the Protection Engine being on causes issues.
- FURRYe38Jan 26, 2026Guru - Experienced User
Try Armor disabled.
Try custom DNS.
PE can be disabled now I believe. Something to try disabled.
