p1r9t3
Dec 03, 2025Aspirant
Brand new BE17000 - No 2.4ghz
I just purchased this BE17000, I set up all of the wireless networks and then turned on guest. For the 2.4ghz guest wifi I gave it a name separate from the rest of them (netgear-iot) and saved the se...
- Dec 06, 2025
I tried the 30-30-30 and the 2.4 came back for about 12 hours and disappeared again.
Just for fun I shut down every device in the house that used 2.4ghz and after a few minutes the SSID re-appeared for me. Started turning things back on one at a time and found that some wifi bulbs I was using were the culprit, as soon as they powered up the wifi dropped. Power down and it came back.
Replaced them with some new bulbs and all is well.
Dec 03, 2025Guru - Experienced User
Try a 30-30-30 reset on the Router. If this fails to bring back 2.4Ghz with SC disabled, then I recommend returning the router to the place of purchase and get another. Possible HW failure on this one unit.
p1r9t3
Dec 06, 2025Aspirant
- FURRYe38Dec 06, 2025Guru - Experienced User
Ah yes, smart bulbs. They have historically have caused odd issues before. Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-routerEnjoy. 📡
