p1r9t3's avatar
p1r9t3
Brand new BE17000 - No 2.4ghz
I just purchased this BE17000, I set up all of the wireless networks and then turned on guest. For the 2.4ghz guest wifi I gave it a name separate from the rest of them (netgear-iot) and saved the se...
  • p1r9t3's avatar
    p1r9t3
    Dec 06, 2025
    I tried the 30-30-30 and the 2.4 came back for about 12 hours and disappeared again.
    Just for fun I shut down every device in the house that used 2.4ghz and after a few minutes the SSID re-appeared for me.  Started turning things back on one at a time and found that some wifi bulbs I was using were the culprit, as soon as they powered up the wifi dropped.  Power down and it came back.
    Replaced them with some new bulbs and all is well.
